NSuku1
7 years agoChange Visual Studio to Eclipse IDE
Hi! I am using Intel High Level Synthesis compiler with Eclipse IDE. When I run the initialization command init_hls.bat I get to see the error "Visual Studio link.exe is not on the path". How ca...
Abe
7 years agoIntel HLS requires Vistual Studio 2015 for compilation. Eclipse is mainly used for Embedded applications targeting NIOS & ARM. GCC toolchain on Windows is used for NIOS and ARM compilation only. If you'd like to use GCC toolchain you will need to use a Linux workstation and the Linux version of Intel Tools.
