10 years ago
Change systemwide paths for project
I'd like to change all paths in my Quartus Project / Eclipse Bsp when copying from a Linux to a Windows PC.
Is it possible without going through every single Makefile (...)?
Especially Eclipse has path related problems.
Mark
    Maybe a bit too much for what you want, but could you use an environment variable?
    When compiling under Eclipse I get:
    10:59:08 **** Build of configuration Nios II for project simpleNiosII ****
    make all
    Das System kann den angegebenen Pfad nicht finden.
    makefile:758: warning: overriding commands for target `obj/default/.metadata/.plugins/org.eclipse.cdt.make.core/specs.o'
    makefile:755: warning: ignoring old commands for target `obj/default/.metadata/.plugins/org.eclipse.cdt.make.core/specs.o'
    Info: Building ../SimpleNiosIIBSP/
    make --no-print-directory -C ../SimpleNiosIIBSP/
    Der Befehl "cygpath" ist entweder falsch geschrieben oder
    konnte nicht gefunden werden.
    process_begin: CreateProcess(NULL, pwd, ...) failed.
    makefile:541: Warning: SOPC File /home/mongoq/projects/kartentricks/simpleNiosII/HostSystem.sopcinfo could not be found.
    make[1]: *** No rule to make target `/system.h', needed by `all'. Stop.
    make: *** [../SimpleNiosIIBSP/-recurs-make-lib] Error 2
    10:59:09 Build Finished (took 530ms)
    How can I change the paths for the whole project without going through makefiles etc. ?
    I want to move projects from one PC to another. I use the same Altera Quartus Prime version - 15.1.
    I thought maybe the archive/dearchive function would allow that. No avail - it stripped off my whole Eclipse BSP C-sourcecode.
