Change default Waveform Editor options
I'm using Intel Quartus 21.1.0 Lite Edition with Questa FSE 2021.2 linux_x86_64.
While trying to make the Simulation Waveform Editor work, I learned that I had to edit the default options of the vsim command within the ModelSim Script.
I need to remove '-novopt' and add '-voptargs=+acc' otherwise I can't get any proper output.
I'd like to know if there is any way to change the default ModelSim Script options so that I don't have to make those edits for each new projects.
Some previous posts suggested to edit the modelsim.ini file, but when I tried it didn't have effect.
It seems that the options get loaded from a pref.tcl file but I couldn't find it.
- YEan
Contributor
Hi there,
The default options of the vsim command can't be changed.
Ean
- YEan
Contributor
We do not receive any response from you to the previous question that have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread.
Thank you.
Ean
- FPOPP1
I have the same problem here. We work with 200+ students, all beginners. The University Program WVF-Simulator has already some problems, but the manual setting of the vsim option '-voptargs=+acc' for each new vector is probably not usable. How can we fix this at the root of the problem? Maybe using a vsim wrapper to correct the options on the fly?
