Case #: 00288368 - Unable to configure Arria 10 GX FPGA Development Kit for OpenCL
- 7 years ago
Copying here a known issue with Ubuntu 16.04 (kernel 4.14 or newer), just in case anyone land here searching on this.
If the board is correctly programmed with a valid OpenCL binary via JTAG and the PCI-E core is enabled, after soft reboot, "sudo lspci -v | grep -i intel" (or altera if you are using older versions of the compiler) should return something. If not, many possibilities exist:
1- Board is not programmed correctly via JTAG.
2- Board has not been seated on the PCI-E port correctly.
3- Board is powered off/broken.
Running aocl flash/program without correctly programming the board and installing the driver and passing aocl diagnose first is pointless.
P.S. This thread might be relevant to your problem:
https://forums.intel.com/s/question/0D50P00003yyToNSAU/arria-10-gx-opencl-setup-question
