Case #: 00288368 - Unable to configure Arria 10 GX FPGA Development Kit for OpenCL
- 7 years ago
Copying here a known issue with Ubuntu 16.04 (kernel 4.14 or newer), just in case anyone land here searching on this.
I'm using 17.1.2.304 as reported by aocl version on Ubuntu 16.04
From Ubuntu 16.04 "aocl install" run with sudo:
aocl install: Running install from /home/user/intelFPGA_pro/17.1/hld/board/a10_ref/linux6/libexec
/home/user/intelFPGA_pro/17.1/hld/board/a10_ref/linux64/libexec/install: 9: [: aclpci_a10_ref_drv: unexpected operator
Looking for kernel source files in /lib/modules/4.15.0-34-generic/build
Using kernel source files from /lib/modules/4.15.0-34-generic/build
Building driver for BSP with name a10_ref
make: Entering directory '/usr/src/linux-headers-4.15.0-34-generic'
CC [M] /tmp/opencl_driver_fon1Cy/aclpci_queue.o
CC [M] /tmp/opencl_driver_fon1Cy/aclpci.o
CC [M] /tmp/opencl_driver_fon1Cy/aclpci_fileio.o
CC [M] /tmp/opencl_driver_fon1Cy/aclpci_dma.o
CC [M] /tmp/opencl_driver_fon1Cy/aclpci_pr.o
CC [M] /tmp/opencl_driver_fon1Cy/aclpci_cmd.o
LD [M] /tmp/opencl_driver_fon1Cy/aclpci_a10_ref_drv.o
Building modules, stage 2.
MODPOST 1 modules
CC /tmp/opencl_driver_fon1Cy/aclpci_a10_ref_drv.mod.o
LD [M] /tmp/opencl_driver_fon1Cy/aclpci_a10_ref_drv.ko
make: Leaving directory '/usr/src/linux-headers-4.15.0-34-generic'
If you notice the unexpected operator error at line 9 of install, I've traced that to the piece of code below. The uninstall script gives the same error, but I don't think it's causing any issues as the MODULE_NAME is being built correctly and it's just the check that's failing.
BSP_NAME=`aocl board-name`
MODULE_NAME=aclpci_$BSP_NAME\_drv
if [ "$MODULE_NAME" == "aclpci__drv" ]
then
echo Failed to determine BSP name
exit 1
fi
aocl flash is exactly the same as Windows 7 - just the help printout.
