Case #: 00288368 - Unable to configure Arria 10 GX FPGA Development Kit for OpenCL
- 7 years ago
Copying here a known issue with Ubuntu 16.04 (kernel 4.14 or newer), just in case anyone land here searching on this.
I believe I was able to confirm that using /sbin/reboot or just restarting windows 7 does not blow way the FPGA that is configuring using quartus_pgm in the "Initializing the Intel Arria 10 GX FPGA Development Kit for use with OpenCL" steps of AN 807.
Basically I watched the behavior of the on board LEDs. From a cold boot they act very different than after the top.sof is programmed via jtag. After a reboot, they do NOT revert to the same behavior as after a cold reboot.
So now I'm stuck. Both in Windows 7 and in Ubuntu 16.04 I get to the "aocl flash boardtext.aocx" step and only get the help message like my arguments are wrong. At this point I have a $5,000 paper weight.
