10 years agoCarry_sum
i'm trying to improve the resolution of my TDC. I am usgin carry_sum (primitive) and i have placed the register near the combcell. Do you know if there is the way to use cin instead DATAD. where can i place my chain inside the FPGA? Thank u very much. Alessia6 Replies
wow. do you understand the architecture of logic element? if no please read about it.
The 'CIN' cannot fed up with signal you provide. it is stored in configuration. Am I wrong? So in you code the very first 'cin' is used in the 2nd LE and in the very last LE you have no 'cout'. i can mistake but it seems you can use '1' or '0' on 'cin' in the very first LE in your chain. but you should provide code that syntethis tool can aware for such situation. - Altera_Forum
--- Quote Start --- wow. do you understand the architecture of logic element? if no please read about it. The 'CIN' cannot fed up with signal you provide. it is stored in configuration. Am I wrong? So in you code the very first 'cin' is used in the 2nd LE and in the very last LE you have no 'cout'. i can mistake but it seems you can use '1' or '0' on 'cin' in the very first LE in your chain. but you should provide code that syntethis tool can aware for such situation. --- Quote End --- Yes i know about it. i was trying to understand what is the best primitive to be used in Cyclone2 for the TDC. - Altera_Forum
why not use instances of dedicated LPM-? they take care for you.
How do you determine 'best'? by Fmax or by number of LE or by power consumption? As for me I don't want to use primitives directly, all you can get comes from written code and assignments. after all why not to consider 'Design Space Explore' ? - Altera_Forum
i would like to know what is the right way to create a chain structure in the FPGA trying to reduce as soon as i can the ultra wide bins.
:) - Altera_Forum
oh dear
try this counter with differnt DATA_WIDTH valuelibrary ieee; use ieee.std_logic_1164.all, ieee.numeric_std.all; entity counter is generic( DATA_WIDTH : positive := 4 ); port( aclr, -- general asynchronus reset clk, -- general synchronous clock sat_in -- previous counter saturated : IN std_logic; o -- counter output value : OUT unsigned(DATA_WIDTH - 1 downto 0); sat_out -- the counter is saturated with all ones : OUT std_logic ); end counter; architecture v1 of counter is constant sat_cond : unsigned(DATA_WIDTH - 1 downto 0) := (0 => '0', others => '1'); signal cnt : unsigned(DATA_WIDTH - 1 downto 0); begin process(aclr, clk) begin if aclr = '1' then cnt <= (others => '0'); sat_out <= '0'; elsif rising_edge(clk) then if sat_in = '1' then cnt <= cnt + 1; end if; if sat_in = '1' then if cnt = sat_cond then -- plan output value in advance sat_out <= '1'; else sat_out <= '0'; end if; end if; end if; end process; o <= cnt; end v1; - Altera_Forum
oh , you can use cover for this
find your DATA_WIDTH and N that conforms youlibrary ieee; use ieee.std_logic_1164.all, ieee.numeric_std.all, work.all; entity CountersTop is generic( DATA_WIDTH : positive := 64; -- counter width N : positive := 4 -- number of slices ); port( r, clk, cu_in : IN std_logic; o : OUT unsigned(DATA_WIDTH - 1 downto 0); cu_out : OUT std_logic ); end CountersTop; architecture rtl of CountersTop is signal internal_cu : std_logic_vector(N - 1 downto 0); constant slice : positive := DATA_WIDTH / N; begin cntrs : for i in 0 to N - 1 generate first : if i = 0 generate cnt1: entity counter(v1) generic map( DATA_WIDTH => slice ) port map( aclr => r, clk => clk, sat_in => cu_in, o => o((I + 1) * slice - 1 downto I * slice), sat_out => internal_cu(i) ); end generate first; follow : if i > 0 generate cntX: entity counter(v1) generic map( DATA_WIDTH => slice ) port map( aclr => r, clk => clk, sat_in => internal_cu(i-1), o => o((I + 1) * slice - 1 downto I * slice), sat_out => internal_cu(i) ); end generate follow; end generate cntrs; cu_out <= internal_cu(N - 1); end rtl;
