10 years agoCarry_sum
Hi, i'm trying to improve the resolution of my TDC. I am usgin carry_sum (primitive) and i have placed the register near the combcell. Do you know if there is the way to use cin instead DATAD. ...
10 years agooh dear
library
ieee;
use
ieee.std_logic_1164.all,
ieee.numeric_std.all;
entity counter is
generic(
DATA_WIDTH : positive := 4
port(
aclr, -- general asynchronus reset
clk, -- general synchronous clock
sat_in -- previous counter saturated
: IN std_logic;
o -- counter output value
: OUT unsigned(DATA_WIDTH - 1 downto 0);
sat_out -- the counter is saturated with all ones
: OUT std_logic
end counter;
architecture v1 of counter is
constant sat_cond : unsigned(DATA_WIDTH - 1 downto 0) := (0 => '0', others => '1');
signal cnt : unsigned(DATA_WIDTH - 1 downto 0);
begin
process(aclr, clk)
begin
if aclr = '1' then
cnt <= (others => '0');
sat_out <= '0';
elsif rising_edge(clk) then
if sat_in = '1' then
cnt <= cnt + 1;
end if;
if cnt = sat_cond then -- plan output value in advance
sat_out <= '1';
else
sat_out <= '0';
end if;
end if;
end if;
end process;
o <= cnt;
end v1; try this counter with differnt DATA_WIDTH value
