12 years ago
Can't use .SDC Example file without errors
I am very new to this and trying to compile an application for an EPM7128S (yes, I know, it's very old).
The compilation goes OK, but I was getting warnings that TimeQuest could not analyse the design because there was no constraints file present.
After a bid of searching, I found the example .SDC file on the Altera website, containing the lines :-
# constrain clock port clk with a 10-ns requirement
create_clock -period 10 [get_ports clk]
# automatically apply a generate clock on the output of phase-locked loops (plls)# this command can be safely left in the sdc even if no plls exist in the design
derive_pll_clocks
# constrain the input i/o path
set_input_delay -clock clk -max 3 [all_inputs]
set_input_delay -clock clk -min 2 [all_inputs]
# constrain the output i/o path
set_output_delay -clock clk 2 [all_outputs] 2
According to the web page, this basic example should be able to work on all designs.
I was getting errors for a couple of LPM_counter modules that I had not declared as clocks, so I added the command
"derive_clocks " which I think should find undeclared clocks?
Anyway, with, or without the modification that I made, the compile fails with the following errors for the .sdc file
Error (332000): More than 2 positional arguments specified: 2, _col4, 2
Usage: set_output_delay [-h | -help] [-long_help] [-add_delay] -clock <name> [-clock_fall] [-fall] [-max] [-min] [-reference_pin <name>] [-rise] [-source_latency_included] <delay> <targets>
-h | -help: Short help
-long_help: Long help with examples and possible return values
-add_delay: Create additional delay constraint instead of overriding previous constraints
-clock <name>: Clock name
-clock_fall: Specifies output delay relative to the falling edge of the clock
-fall: Specifies the falling output delay at the port
-max: Applies value as maximum data required time
-min: Applies value as minimum data required time
-reference_pin <name>: Specifies a port in the design to which the output delay is relative
-rise: Specifies the rising output delay at the port
-source_latency_included: Specifies input delay already includes added source latency
<delay>: Time value
<targets>: Collection or list of output ports
while executing
"set_output_delay -clock clk 2 [all_outputs] 2"
(file "MTXPlus_CPU.sdc" line 22)
Can anyone tell me where I've gone wrong please?
regards
Dave
    looks like you have passed a typo:
    should be
    but remember in reality these figures are not general and you need to adjust them per your io case
    Hi Kaz,
    Thanks a lot for the reply.
    Actually, the code is pasted straight off the Altera web page here:-
    http://www.altera.co.uk/support/examples/timequest/exm-tq-basic-sdc-template.html
    Thanks for the fix though, I will make change in the morning, or should I say, later in the morning!
    It's nearly 2AM here.
    (I have changed the clock period to suit my case)
    Dave
    Update : Thanks Kaz, that fixed it.
    Off to ask my next question now though :-)
