can't programming a Cyclone V E Development kit
Hey,
I unsuccessfully tried to program a Cyclone V E Development kit to the CFI flash 512Mb on the kit.
I converted the sof file (that I successfully download to the kit) to a pof file via the Convert Programming File in Quartus application. I converted it to 1-bit Passive serial, according the next figure that you can fined in page number 22 in the device's datasheet:
This is the JTAG chain that I constructed in Quartus programmer:
When I tried to burn the pod file into the flash, I got the message that I don't have the PFL file that required (in data sheet it mentioned that the Parallel Flash Loader is included).
Moreover, I tried the JTAG chain with the FPGA master over the Flash device. In this scheme I expected to get the PFL file automaticlly but it didn't upload and I got the same error when I tried to burn the pof file
Can you help me?
Thank you
- JohnT_Altera
In order to program the CFI flash, I would recommend you to use Nios II EDS or Board Update Portal. Please refer to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_cve_fpga_dev_kit.pdf Page 31.
- Gyud0
hey John,
I can't program the FPGA kit via the Quartus programmer?
- JohnT_Altera
Could you confirm if you have configure the Max or FPGA with PFL design? If yes, may I know what is the error message that you are observing?
Have you try the development kit user guide to see if you are able to update the flash?
- Gyud0
I tried to configure it as I showed in the pictures above. I got the errors:
"Flash Loader IP not loaded on device 1"
- JohnT_Altera
Have you program the CPLD/FPGA 1st with PFL before programming the flash? Have you tried the step provide in user guide?
- Gyud0
Do I need to add the PFL IP to the design?
because page 21 mentioned that the development board implements the Altera PFL mega function.
- JohnT_Altera
If you are using your own design then you will need to include PFL. If you are using factory design, then it should include the PFL into the bitsream
- Gyud0
ok.
So I did the folowwing steps:
1) I reviewed the MSEL pin settings for Cyclone V devices .
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-v/cv_5v2.pdf
you can see that in page 244. I'm interesting in Active Serial X4 configuration so I configured the SW1 on the Evaluation kit. I tried the both remarked option bits
2) In Quartus project, In configuration (belongs to device and pin options), I chose:
Configuration scheme: Active serial X4
Configuration mode: Standard
Use configuration device:EPCQ256
Configuration device I/O voltage: Auto
Active serial clock source:100MHz internal oscillator
3) I used the Convert Programming file window via Quartus and chose:
programming file type: .jic
Configuration device: EPCQ256
Model: Active serial x4
Flash Loader-> 5CEFA7
SOF Data-> project_file.sof
4)Via the Programmer windows I constructed the following chain:
And I pressed the Start button
I got the messages:
"209060- Started programmer operation at <Local_Time>"
"209016 Configuring device index 1"
"209017- Device 1 contains JTAG ID code 0x02B130D0"
"209007 Configuration succeed --1 device(s) configured"
"209025 can't recognized silicon ID for device 1. A device's silicon ID is different from its JTAG IS. verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly"
"209012 Operation failed"
"209061 Ended programmer operation at <Local_Time> "
- JohnT_Altera
Could you try to performed Auto-detect after the failure? The reason is that I suspect that the flash device is not EPCQ256.
When you are generating jic file, could you click in the "Advanced..." button to see if the "Disable EPCS/EPCQ ID check" is enabled?
- Gyud0
1)When I'm generating the JIC file, the "Disable EPCS/EPCQ ID check" is enabled.
2)I did an Auto-detect after the failure and I got the message "The auto-detected device chain doesn't match the programming device list....." . So do I need to try it on another EPCQ device?
- JohnT_Altera
Could you provide the screenshot of the new JTAG chain device list?
