Gyud0
5 years agocan't programming a Cyclone V E Development kit
Hey,
I unsuccessfully tried to program a Cyclone V E Development kit to the CFI flash 512Mb on the kit.
I converted the sof file (that I successfully download to the kit) to a pof file via the Co...
JohnT_Altera
5 years agoHi,
Could you try to performed Auto-detect after the failure? The reason is that I suspect that the flash device is not EPCQ256.
When you are generating jic file, could you click in the "Advanced..." button to see if the "Disable EPCS/EPCQ ID check" is enabled?
- Gyud05 years ago
1)When I'm generating the JIC file, the "Disable EPCS/EPCQ ID check" is enabled.
2)I did an Auto-detect after the failure and I got the message "The auto-detected device chain doesn't match the programming device list....." . So do I need to try it on another EPCQ device?
