10 years agoCan't place differential Pins, seems like a glitch
I want to use a memory controller and for that I was assigning all necessary pins. Since I've built the project several times already (I had to start a new project FYI) I know how the Pins have to be assigned and it was always working and is working with these settings in another project. However I get the following Errors: Error (169290): Can't place differential I/O positive pin DDR3_CK_n at a differential I/O negative location AA15(PAD_120) Error (169290): Can't place differential I/O positive pin DDR3_DQS_n[0] at a differential I/O negative location W16(PAD_136) Error (169290): Can't place differential I/O positive pin DDR3_DQS_n[1] at a differential I/O negative location W17(PAD_152) Error (169290): Can't place differential I/O positive pin DDR3_DQS_n[2] at a differential I/O negative location AA18(PAD_168) Error (169290): Can't place differential I/O positive pin DDR3_DQS_n[3] at a differential I/O negative location AD19(PAD_184) When I switch for example DDR3_CK_n with the respective positive Pin DDR3_CK_p, it gives the exact same error message for DDR3_CK_p. Does anyone have a clue what I could do to fix this? Thanks in advance,:) Z1 Reply
If you check the specific pin ie AA15 at the pin planner, does it show positive or negative pin?
