Altera_ForumHonored Contributor14 years agoCan't place all RAM cells in design Hi, I´m using a Stratix III FPGA board EP3SL150F1152C2 and I try to build up a NiosII Core. My components are a clock, onchip memory, NIOS II Core and some more. Now I got a problem when i comp...Show More
Altera_ForumHonored Contributor14 years agoThanks!!! It works now. I just reduce the memory size how you told to do!
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
