Can't Open Encrypted VHDL File
- 3 years ago
With the following steps:
Go to Tools -> Platform Designer -> Load Computer_System.qsys -> Generate HDL (right-bottom) -> Recompile
I'm able to compile with the Quartus Lite v20.1 check image below:
File attached below for your reference. May extract and compile.
Sheng
If want to use version 20.1, have to open Computer_System.qsys and re-generate HDL. After that, recompile then the problem can be bypassed.
For version 21.1, the simulator supported is Questa which requires license.
Sheng
Thanks so much for the info.
How do you re-generate the HDL in Quartus Prime Lite?
