Can't Open Encrypted VHDL File
- 3 years ago
With the following steps:
Go to Tools -> Platform Designer -> Load Computer_System.qsys -> Generate HDL (right-bottom) -> Recompile
I'm able to compile with the Quartus Lite v20.1 check image below:
File attached below for your reference. May extract and compile.
Sheng
If want to use version 20.1, have to open Computer_System.qsys and re-generate HDL. After that, recompile then the problem can be bypassed.
For version 21.1, the simulator supported is Questa which requires license.
Sheng
- MReha23 years ago
Thanks so much for the info.
How do you re-generate the HDL in Quartus Prime Lite?
