Can't Open Encrypted VHDL File
- 3 years ago
With the following steps:
Go to Tools -> Platform Designer -> Load Computer_System.qsys -> Generate HDL (right-bottom) -> Recompile
I'm able to compile with the Quartus Lite v20.1 check image below:
File attached below for your reference. May extract and compile.
Sheng
I guess you're downloading version 21.1 Monitor Program. It's recommended to use Quartus Lite version 21.1 and above. If not, probably there'll be some ip version mismatch issue like what you mentioned. If want to use version 20.1, have to regenerate HDL of the Computer_System.qsys and add in the newly generated .qip file.
Btw, I'm able to compile the project with Quartus Lite v21.1 check image below:
Sheng
- MReha23 years ago
I am already able to compile with 21.1.
I am not able to compile with 20.1 (I get the error as noted).
I would like to use 20.1 because ModelSim without any licensing hassles are included with 20.1.
I am a professor so licensing things can be a challenge with a large class size.
Either.....
How can I fix the error noted in 20.1?
Or....
How can I get ModelSim (or equivalent) working in 21.1 without all the licensing hassles?
