--- Quote Start ---
Had the same problem. Solved it as follows:
open .BDF file with text-editor ... search "" ... insert text as follows "Hello" ... save file ... open file in schematic-editor an search/replace Hello with the apropriate test.
--- Quote End ---
Hi. I am facing the same problem. I tried replacing one of the pin names "A[7]" with "Hello" in notepad, then saved the file. Then tried to open it in the schematic. But it still wont open. Can you please help me out here.
That schematic contained an entire day of work.
Thanks in advance
