--- Quote Start ---
Hi everybody,
I have a problem with a .bdf file; Quartus v.8.1 refuses to open it
It was a very important block diagram (970 Kb) with a lot of blocks (over 250). During a compilation (Ctrl+K) the software crashed and now I'm unable to open the file. Do you know any method to recover my work?
If you are interested, I can attach the file...
Thank you for the attention.
--- Quote End ---
post your project if possible. Did you move the project ? Check the paths to your design files. Sometimes it helps when yon delete the db folder in the project.
Kind regards
GPK
