- ChrisS
Hi @Abe ,
Would you be so kind and also provide direct links to download Quartus Subscription Edition 13.0sp1? I need that version for its support of Cyclone II and Stratix III, but the download center isn't letting me log in (the login request times out with "504 Gateway Time-out", I think this is still the same issue others had 4 months ago...). I tried multiple times and I wasn't able to make it work. Thank you!
- RMust
@Abe Thank you!
- ELuco
6 Months later, and I still ran into this issue...inspecting the Chrome errors shows they need to fix their web-site:
Access to XMLHttpRequest at 'https://www.intel.com/libs/apps/intel/login.json/securitytoken' from origin 'http://fpgasoftware.intel.com' has been blocked by CORS policy: The 'Access-Control-Allow-Origin' header has a value 'https://fpgasoftware.intel.com' that is not equal to the supplied origin.
assetLoader.min.js:188 Cross-Origin Read Blocking (CORB) blocked cross-origin response https://www.intel.com/libs/apps/intel/login.json/securitytoken with MIME type application/json. See https://www.chromestatus.com/feature/5629709824032768 for more details
There are also a half a dozen "not found" errors in there for various things, as well as this gem:
dlm.js:3317 GET http://127.0.0.1:9421/api?function=getClientAttributes&installcpcode=78333&cid=0&complete&wrapper=DLMHelper.setInstalled(*);&r=0.9376153327377006&apiversion=jsapi_1.9.7.2 net::ERR_CONNECTION_REFUSED
I love that it's attempting to access something at localhost.
The only way I could get the files was to follow the advice above and start off at the right domain.
- JBERK3
Registered, but Intel just doesn't allow us to login. So after they forced us to go for the obvious alternative solution to carry on, the question is will we ever look back for the next project, or stay with what we already comfortable with by then?
- FolicM
Hi, I'm also having trouble with logging in and I can't download any software. Can someone post a download link for Altera quartus ii 13.1 web edition?
- HTAO01
I'm also having trouble with logging in and I can't download any software. Can someone post a download link for Altera quartus ii 16.0 and cyclone V's .qzf?
- ASmit82
Intel really needs to fix this... Its still an issue one year later :/
- DFlix
Same issue. This is honestly a pretty embarrassing problem Intel. I've never had any issues downloading Xilinx tools.
