Can't launch Questa from Quartus
- 3 years ago
This is a known issue in Quartus lite 22.1. So you will need add a double quote on line 122 in the qnativelinkflow.tcl file located at the <Intel® Quartus® Installation Path>/quartus/common/tcl/internal/nativelink directory.
From this :
set questa_installation "$questa_fse_directory
To:
set questa_installation "$questa_fse_directory"
Another forum thread with same issue:
From this :
To:
- Fuad13 years ago
Thank you. the problem is solved using the solution that you suggested.
