9 years agoCan't get the proper data from custom component through IORD(from io.h file) macro.
Hello, I have designed a MM slave component which includes 2 conduit interface and a 8 bit register and I want to read data from that register but some how I can't get the data. The simulati...
9 years agoyeah I got the garbage value but at the same time the read signal should goes to higher level (logic 1) but it didn't.
and after writing some data to that component i got both the wire pulse and well as read pulse so what should I do if I want only read operation.
