9 years agoCan't get the proper data from custom component through IORD(from io.h file) macro.
Hello, I have designed a MM slave component which includes 2 conduit interface and a 8 bit register and I want to read data from that register but some how I can't get the data. The simulati...
9 years agoDo you have a known, fixed value in the register map of your slave that you can look for? Then you'd know if it was garbage or not.
Cheers, Alex
