14 years ago
Can't Generate Symbol File - Read-Only Error
In Windows for Quartus II v11.0 I can't generate a symbol file (or AHDL, or anything else) for a bdf file. It says "Can't open read-only file" and the path name. What I've tried:
Run as administrator
in DOS ran attrib -r /s /d on whole folder
Generate symbol file to a different directory
Windows 7 or XP
HELP! I'm dead in the water.
Thanks!
Bruce
    I don't have a previous install of quartus on this pc, but I get around the bug by creating a file of the same name as my intended symbol name (can be an empty file, doesn't matter), then when I create the symbol in quartus it overwrites this file successfully.
    Annoying but at least it's not too much effort to get around.
    It's still around under Linux as well with 11.0 :( creating cmp file, workaround on the command line is to 'touch' the filename to create it then set permissions to rwx for all (chmod 777)
