Altera_ForumHonored Contributor14 years agoCan't Generate Symbol File - Read-Only Error In Windows for Quartus II v11.0 I can't generate a symbol file (or AHDL, or anything else) for a bdf file. It says "Can't open read-only file" and the path name. What I've tried: Run as admin...Show More
Altera_ForumHonored Contributor14 years agoi see you couldn't create AHDL, i converted to Verilog then to .bsf
Recent DiscussionsDo we need to manually Pin map HBM m2u Interface portsSolvedCYCLONE IVE ODDR delay mismatchSolvedIs Quartus Prime Pro 22.4 Compatible with Stratix 10 NX Series Device 1SN21CEU2F55E2VG?Questa 2 licenses?Agilex 7 boot from config flash over JTAG
