16 years ago1 - Delete the "db" directory.
2 - markman may be right. Check the versions on your licenses (YYYY.MO). If they are pre-9.1 time-frame you may not have a license for that IP core in 9.1. You should still be able to find a way to use the 9.0 version of the core in 9.1 if you like. Jake
