Altera_ForumHonored Contributor16 years agoCan't generate programming file When I compiled a project , quartus ii v9.1 doesn't generate the programming file. Below is the message. Info: Compilation Report contains advance information. Specifications for device EP4SE530F4...Show More
Altera_ForumHonored Contributor16 years agoTry: setting->Device and Pin Options->Configuration laoxizi
Recent DiscussionsQuartus Lite 23.1 MAX 10 EncryptionHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:
