10 years agoCan't determine definition of operator ""srl""
Hallo This is my first project with Altera. I am using the quatras 2 synthesis tool and simulink to generate a design for my FPGA. But when i try to synthesis the code i get the following error...
10 years agoFor some reason it is trying to shift a real, which is not possible. You need to convert all of your code to use fixed point numbers, not floating, because floating will not be synthesisable.
