10 years agoCan't create a VHDL file in Quartus
Hi, I have been trying to create a VHDL file for block diagram. The project compiles without problems, but when trying to create a HDL file for current file it shows an error. Hence I cannot pr...
10 years ago --- Quote Start --- The screenshot is too small to be readable. But do your signal names all meet VHDL requirements: ie. must start with a letter. Can only contain alpha numeric characters and underscore (a-z, 0-9, _). VHDL is also case insensitive, so have you got any duplicate names through different cases. eg. nCS and ncs (same name in VHDL). --- Quote End --- Hi, thank you for getting back to me, and I do apologise for unclear screenshot. The error message I get is: "Name "OF" contains VHDL keyword". I used symbol from quartus library BCD to 7 Segment (7447) and I would expect it to work and produce the VHDL file when prompted. Thank you Tom
