笔书香
7 years agoCannot run SignalTap II Logic Analyzer. SignalTap II File is not compatible with the file programmed in your device
Quartus Prime 15.1 Standard Edition Version Found: v15.1
1 Reply
- AnandRaj_S_Intel
which device is used for your design?
can you attache the error message & .qsf file?
Point to note
- Project Navigator should have .stp file.
- Also go to Assignments -> Settings -> SignalTap II Logic Analyzer->Enable SignalTap II Logic Analyzer ->browse the path of the stp.
- Power cycle your board.
Anand
