Cannot proceed because MSVCR120.dll was not found
Recently I have installed intel quartus prime pro and using it. I have tried to run modelsim, and it shows this error.
" The code execution cannot proceed because MSVCR120.dll was not found. Reinstalling the program may fix this problem."
I am unable to run it because of this error. I have searched about the error and found a answer that , install MS VC++ and I have installed 2013 version of that also..
Kindly help me to run this..
Thanks and Regards
MuralikumarM
Please check that the LM_LICENSE_FILE is directed to a license file. Modelsim Intel Edition required a license.
How to set LM_LICENSE_FILE:
In the command prompt:
setx LM_LICENSE_FILE <license file path>example: C:\intelFPGA_pro\21.1\license.dat
Richard Tan
- RichardT_altera
You may checkout the link below for the solution.
Let me know if it helps.
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.- MuralikumarM
Hi @Richard Tan
Thanks for your response.
I found the dll file and replaced it with new one but again i am getting same error.
Please provide other possibilities to try and solve the problem.
MuralikumarM- RichardT_altera
Do you download the Modelsim installer from our Download Center for FPGAs?
https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
Try to uninstall the current Modelsim and install the Modelsim - Intel FPGA edition.
Let me know if the issue persists.
Richard Tan
