14 years ago
Cannot get usbblaster working on linux64
I have redhat enterprise 5 64 bit linux installed. I installed the quartus II version 11 web edition to /usr/share/Altera/quartus
I get the following message every time I try to run the GUI or the jtagconfig programs:
"The Quartus II software cannot be started because the current platform, linux64, does not appear to be installed in /usr/share/Altera/quartus"
I then browsed that directory, and there is no linux64 folder present. There is a "linux" folder though. It seems that my install does not install a "linux64" folder.
This does not seem to stop the program from starting though. The GUI will then start up just fine after this message is displayed in the terminal.
The problem I am having is that I cannot get the USBblaster to work. No matter what I do it will not show up in the add hardware dialog.
I have tried changing the permissions in the .rules file. I have tried mounting the usbfs. I tried running as root.
Is the usbblaster not compatable with linux64? Does this have something to do with the linux64 folder not being in my directory?
    edit:
    I wiped my quartus install and started from scratch.
    From there I copied the linux directory and renamed it linux64 so I have both a linux and linux64 directory in my quartus directory.
    After that I went and did the jtag configuration, and now everything seems to work fine.
    Thanks for your help.. that thread seems to have solved the probblem.
    --- Quote Start ---
    edit:
    --- Quote End ---
    I had the same problem, usign OS Red Hat Enterprise Linux 5 (RHEL 5) and Quartus 11.0 instaled.
    After I follow the steps of this link and have no sucess, I copied <..>/quartus/linux and rename to <...>/quartus/linux64. And it works!
    Thank you for solution.
