8 years agoCannot get JTAG Device to show up in Quartus
I am using the S10 SoC Development Kit, with Quartus 18.0.
I cannot get the configuration hardware to show up in programmer. I've followed the steps listed in this excellent tutorial: http://www.fpga-dev.com/altera-usb-blaster-with-ubuntu/ Any tips will be appreciated. quartus version 18.0 >> /tools/intelFPGA_pro/18.0/quartus/bin/quartus >> lsusb Bus 001 Device 011: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC >> dmesg [ 1153.023826] usb 1-13: FTDI USB Serial Device converter now attached to ttyUSB0 >> Ubuntu Version Linux version 4.13.0-41-generic (buildd@lgw01-amd64-028) (gcc version 5.4.0 20160609 (Ubuntu 5.4.0-6ubuntu1~16.04.9))# 46~16.04.1-Ubuntu SMP Thu May 3 10:06:43 UTC 2018 >> strace jtagd --foreground --debugexecve("/tools/intelFPGA_pro/18.0/quartus/bin/jtagd", , ) = 0
brk(NULL) = 0x9ef000
access("/etc/ld.so.nohwcap", F_OK) = -1 ENOENT (No such file or directory)
access("/etc/ld.so.preload", R_OK) = -1 ENOENT (No such file or directory)
open("/etc/ld.so.cache", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=89170, ...}) = 0
mmap(NULL, 89170, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7fe5b6911000
close(3) = 0
open("/lib/x86_64-linux-gnu/libtinfo.so.5", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0p\310\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=167240, ...}) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fe5b6910000
mmap(NULL, 2264256, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fe5b64d9000
mprotect(0x7fe5b64fe000, 2093056, PROT_NONE) = 0
mmap(0x7fe5b66fd000, 20480, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x24000) = 0x7fe5b66fd000
close(3) = 0
open("/lib/x86_64-linux-gnu/libdl.so.2", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\240\r\0\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0644, st_size=14608, ...}) = 0
mmap(NULL, 2109680, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fe5b62d5000
mprotect(0x7fe5b62d8000, 2093056, PROT_NONE) = 0
mmap(0x7fe5b64d7000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x2000) = 0x7fe5b64d7000
close(3) = 0
open("/lib/x86_64-linux-gnu/libc.so.6", O_RDONLY|O_CLOEXEC) = 3
read(3, "\177ELF\2\1\1\3\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0P\t\2\0\0\0\0\0"..., 832) = 832
fstat(3, {st_mode=S_IFREG|0755, st_size=1868984, ...}) = 0
mmap(NULL, 3971488, PROT_READ|PROT_EXEC, MAP_PRIVATE|MAP_DENYWRITE, 3, 0) = 0x7fe5b5f0b000
mprotect(0x7fe5b60cb000, 2097152, PROT_NONE) = 0
mmap(0x7fe5b62cb000, 24576, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_DENYWRITE, 3, 0x1c0000) = 0x7fe5b62cb000
mmap(0x7fe5b62d1000, 14752, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7fe5b62d1000
close(3) = 0
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fe5b690f000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fe5b690e000
mmap(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7fe5b690d000
arch_prctl(ARCH_SET_FS, 0x7fe5b690e700) = 0
mprotect(0x7fe5b62cb000, 16384, PROT_READ) = 0
mprotect(0x7fe5b64d7000, 4096, PROT_READ) = 0
mprotect(0x7fe5b66fd000, 16384, PROT_READ) = 0
mprotect(0x6f3000, 4096, PROT_READ) = 0
mprotect(0x7fe5b6927000, 4096, PROT_READ) = 0
munmap(0x7fe5b6911000, 89170) = 0
open("/dev/tty", O_RDWR|O_NONBLOCK) = 3
close(3) = 0
brk(0x9f0000) = 0x9f0000
open("/usr/lib/locale/locale-archive", O_RDONLY|O_CLOEXEC) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=2981280, ...}) = 0
mmap(NULL, 2981280, PROT_READ, MAP_PRIVATE, 3, 0) = 0x7fe5b5c33000
close(3) = 0
brk(0x9f1000) = 0x9f1000
brk(0x9f2000) = 0x9f2000
getuid() = 1001
getgid() = 1001
geteuid() = 1001
getegid() = 1001
rt_sigprocmask(SIG_BLOCK, NULL, , 8) = 0
brk(0x9f3000) = 0x9f3000
sysinfo({uptime=1780, loads=, totalram=99814060032, freeram=98714148864, sharedram=10485760, bufferram=47362048, totalswap=101539901440, freeswap=101539901440, procs=483, totalhigh=0, freehigh=0, mem_unit=1}) = 0
brk(0x9f4000) = 0x9f4000
rt_sigaction(SIGCHLD, {SIG_DFL, , SA_RESTORER|SA_RESTART, 0x7fe5b5f404b0}, {SIG_DFL, , 0}, 8) = 0
rt_sigaction(SIGCHLD, {SIG_DFL, , SA_RESTORER|SA_RESTART, 0x7fe5b5f404b0}, {SIG_DFL, , SA_RESTORER|SA_RESTART, 0x7fe5b5f404b0}, 8) = 0
rt_sigaction(SIGINT, {SIG_DFL, , SA_RESTORER, 0x7fe5b5f404b0}, {SIG_DFL, , 0}, 8) = 0
rt_sigaction(SIGINT, {SIG_DFL, , SA_RESTORER, 0x7fe5b5f404b0}, {SIG_DFL, , SA_RESTORER, 0x7fe5b5f404b0}, 8) = 0
rt_sigaction(SIGQUIT, {SIG_DFL, , SA_RESTORER, 0x7fe5b5f404b0}, {SIG_DFL, , 0}, 8) = 0
rt_sigaction(SIGQUIT, {SIG_DFL, , SA_RESTORER, 0x7fe5b5f404b0}, {SIG_DFL, , SA_RESTORER, 0x7fe5b5f404b0}, 8) = 0
rt_sigaction(SIGQUIT, {SIG_IGN, , SA_RESTORER, 0x7fe5b5f404b0}, {SIG_DFL, , SA_RESTORER, 0x7fe5b5f404b0}, 8) = 0
uname({sysname="Linux", nodename="snic1", ...}) = 0
brk(0x9f5000) = 0x9f5000
brk(0x9f6000) = 0x9f6000
brk(0x9f7000) = 0x9f7000
brk(0x9f8000) = 0x9f8000
stat("/home/******", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
stat(".", {st_mode=S_IFDIR|0755, st_size=4096, ...}) = 0
getpid() = 2897
open("/usr/lib/x86_64-linux-gnu/gconv/gconv-modules.cache", O_RDONLY) = 3
fstat(3, {st_mode=S_IFREG|0644, st_size=26258, ...}) = 0
mmap(NULL, 26258, PROT_READ, MAP_SHARED, 3, 0) = 0x7fe5b6920000
close(3) = 0
getppid() = 2895
brk(0x9f9000) = 0x9f9000
brk(0x9fa000) = 0x9fa0004 Replies
Did you use the correct USB contact on the kit? There is at least one contact for the integrated USB blaster, and one for the UART. It looks like the one you have connected is the UART. AFAIK the USB blaster should show as "Altera Blaster" in lsusb (at least it does with the USB Blaster I).
--- Quote Start --- Did you use the correct USB contact on the kit? There is at least one contact for the integrated USB blaster, and one for the UART. It looks like the one you have connected is the UART. AFAIK the USB blaster should show as "Altera Blaster" in lsusb (at least it does with the USB Blaster I). --- Quote End --- Is the USB Blaster-I needed? I have a simple USB to mini-USB connection between the PC and the board. Thanks, Salma - Altera_Forum
I moved the cable to J57, and it showed up as an Altera device! Thanks for your inputs.
Glad you fixed it. No I didn't meant you needed a USB Blaster I, it's just that currently the only linux machine I have access to that is connected to a USB Blaster has a USB Blaster I, so that was the only info I could give about the output from lsusb.
The Soc devkit has an on-board USB Blaster II if I remember correctly.
