8 years agoCannot get JTAG Device to show up in Quartus
I am using the S10 SoC Development Kit, with Quartus 18.0. I cannot get the configuration hardware to show up in programmer. I've followed the steps listed in this excellent tutorial: http://www...
8 years ago --- Quote Start --- Did you use the correct USB contact on the kit? There is at least one contact for the integrated USB blaster, and one for the UART. It looks like the one you have connected is the UART. AFAIK the USB blaster should show as "Altera Blaster" in lsusb (at least it does with the USB Blaster I). --- Quote End --- Is the USB Blaster-I needed? I have a simple USB to mini-USB connection between the PC and the board. Thanks, Salma
