Cannot Generate Timing Report in TimeQuest Timing Analyzer
Hi Ted,
When we debug your design with the JTAG interface, the JTAG signals TCK, TMS, TDI, and TDO are implemented as part of the design.
The altera_reserved_tck/tms/tdi pin is automatically generated for a design that uses a JTAG accessible module such as the Nios II debugger, SignalTap II logic analyzer, and In-System Memory Content Editor.
For timing constraint those pins
To constrain this JTAG clock, apply a 33-MHz clock constraint to this pin.
For the TimeQuest Timing Analyzer, use the following command:
create_clock -period "30.303 ns" -name {altera_reserved_tck} {altera_reserved_tck}
Reference
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/solutions/rd04282008_867.html
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/mnl_timequest_cookbook.pdf
Anand
