8 years agocannot generate ddr3 core quartus 16.0
I am having a frustrating issue where i am unable to generate a ddr3 core throught the ip catalog. I configure the core i want in the ip catalog and when go to generate the generation wizard ha...
8 years agoCan you post the parameter settings you've chosen? Perhaps you've put in a mix that is not supported on your device but for some reason isn't causing the generation to fail.
