8 years agocannot generate ddr3 core quartus 16.0
I am having a frustrating issue where i am unable to generate a ddr3 core throught the ip catalog. I configure the core i want in the ip catalog and when go to generate the generation wizard ha...
8 years agoI am targetting the Max10 speed grade 6. The only warnings i get are:
Warning: ddr3_max_111: ODT is disabled. Enabling ODT (Mode Register 1) may improve signal integrity Warning: ddr3_max_111.pll_bridge: pll_bridge.pll_sharing cannot be both connected and exported I am assuming the ODT is not the problem since it has to do with signal integrity. The second warning can be ignored according to: https://www.altera.com/support/support-resources/knowledge-base/solutions/fb203048.html I have let the wizard run over night and it still doesn't make it any further then described above...
