8 years ago
Cannot edit the generated PLL Intel FPGA IP v18.0
Hi All,
I am using Quartus Prime v18.0 and generated PLL IP v18.0. I have successfully generated the PLL and added into the project but when I tried to modify it in the IP components, the MegaWizard failed to launch, below is the complete message of the problem.
"Failed to launch MegaWizard Plug-In Manager. PLL Intel FPGA IP v18.0 could not be found in the specified library paths."
See attachment for the screenshot.
I tried other IP components, like FIFO, ALTLVDS_RX, ALTLVDS_TX, ALTCLKCTRL, all of it works fine.
Quartus Prime: Version 18.0.0 Build 614 04/24/2018 SJ Standard Edition
Target Device: Arria V GX (5AGXBB3D4F35I5)
Machine: Windows 10 Pro 64bit
Also, I tried the same thing on other PC (Windows 7) but the problem is the same.
Need help to fix this issue.
Thank You.
Zeahr
