12 years agoThank you, Daixiwen!
I found the 4-th chapter of unknown document - ch.4 "Nios II Command-Line Tools". There are many interesting items in it. But though the document was revised in 2011 it contains the SOPC builder commands and no commands for the Qsys. I believe the SOPC builder is already obsolete? There are examples how to use commands. But I would like to have an opportunity to learn somehow what does a specific command mean. For example where can I learn how to unterprit a command - set_global_assignment -name SEARCH_PATH $::quartus(qip_path) (This is contained in the meminit.qip) I found the Bash Reference Manual in the Inet but not such a command yet. If you can influence on the Altera support it is desirable for them not to hide the list and syntax of the bash commands and command-line commands. Regards, tduty
