12 years agoHello, Daixiwen!
Many various attempts to create my own software project were unsuccessful. And at last the following was successful. According to the ch.2 of the Nios II Software Developer's Handbook I followed "Creating a Project" and "Nios II Application and BSP from Template". Many details are described there but one must guess to choose "Blank Project" if he wants to create his own. Then on the second page you are suggested to create a new BSP. But how to do it? Be patient! Read some new items of the Handbook and learn to click FINISH to create the projects. Though when you select an existing project there is the "Create" button for it. Then you must build the Project (the only one or may be both?). Every time I tried to build the application project and got the error message. But today I chose the BSP project building first and only then the application building. That was the reason I could not get the compiled project. Though it's written in the Handbook that SBT builds the dependency (i.e. BSP) project first. But it does not do it itself! So I could create all the projects. Everything is OK. One my question remains. I would like to become acquainted with the bash commands and command-line commands syntax. Where to learn it? Thank you for your help. I thank benc for his help too. Regards, tduty
