12 years agoHello, Daixiwen!
I knew you are the skilful expert and could make sure it was right. I recompiled my projects using the jtag uart, created the .hex file, included it and the .qip file into the hardware project, recompiled it and downloaded the new .sof. Of course my application did not start as you warned about. But after I started the nios2-terminal in the command shell - leds began blinking and the Nios console window began to display numbers from the counter used in my application. That is you've been quite right. Thank you. But now another issue pursues me. I cannot create my own BSP project. The Nios II Software Developer's Handbook and the Embedded Design Handbook give cross references to each other. More over one can find a list of steps to create the BSP project but no advice how to fulfill them. One is advised to start with the Nios II BSP Editor - I do it but all its tabs are grey. Another way - use the command line but where to learn the commands syntax? One way more - use the old project but I get a message that the project already exists and cannot modify it. Could not you advise where one may read the rules how to create a BSP project (and then the software application project) not from the template but - from the very beginning, - from the existing project. Regards, tduty
