16 years ago
Cannot change the "Compile test bench" in 10.0
I'm using Quartus 10.0. When I change the the "Compile test bench" drop-down list , the "Apply" button is still disabled. And It always runs the first test bench. I've checked the .qsf file. It is not changed too. Does anyone have this issue too?
1 Reply
    i run into the same thing here, if you have mutliple testbench setups in NativeLink under Assignments > Settings > EDA Tool Settings > Simulation, it doesn't seem possible to select the 2nd test bench
    editing the .qsf EDA_NATIVELINK_SIMULATION_TEST_BENCH statement to your 2nd testbench name should be a work around. have you tried this?
