15 years agoi run into the same thing here, if you have mutliple testbench setups in NativeLink under Assignments > Settings > EDA Tool Settings > Simulation, it doesn't seem possible to select the 2nd test bench
editing the .qsf EDA_NATIVELINK_SIMULATION_TEST_BENCH statement to your 2nd testbench name should be a work around. have you tried this?
