11 years ago
can you find the small error for me,sir............ :(
this is the time to show in LCD. i cannot find the problem. i want to show hour for 01-12. but its also include 00. so after 12hr it become 00hr and then 01 hr. that is the wrong. can u find the error, sir. plz help me. that is very important for me ................. thank sir
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity counter_up is
Port ( clk : in STD_LOGIC;
SET : in STD_LOGIC;
BTN0 : in STD_LOGIC;
BTN1 : in STD_LOGIC;
BTN2 : in STD_LOGIC;
BTN3 : in STD_LOGIC;
BTN4 : in STD_LOGIC;
BTN5 : in STD_LOGIC;
reset : in STD_LOGIC;
AM : out STD_LOGIC;
hex0 : out STD_LOGIC_VECTOR (3 downto 0);
hex1 : out STD_LOGIC_VECTOR (3 downto 0);
hex2 : out STD_LOGIC_VECTOR (3 downto 0);
hex3 : out STD_LOGIC_VECTOR (3 downto 0);
hex4 : out STD_LOGIC_VECTOR (3 downto 0);
hex5 : out STD_LOGIC_VECTOR (3 downto 0));
end counter_up;
architecture Behavioral of counter_up is
signal count0:std_logic_vector(3 downto 0):=(others=>'0');
signal count1:std_logic_vector(3 downto 0):=(others=>'0');
signal count2:std_logic_vector(3 downto 0):=(others=>'0');
signal count3:std_logic_vector(3 downto 0):=(others=>'0');
signal count4:std_logic_vector(3 downto 0):=x"1";
signal reg:std_logic:='0';
begin
process(clk,reset)
begin
if reset='1' then
count0<=(others=>'0');
count1<=(others=>'0');
count2<=(others=>'0');
count3<=(others=>'0');
count4<=x"1";
elsif rising_edge(clk) then
if SET='1' then
if (count0=x"9" and BTN0='1') then
count0<=x"0";
elsif (BTN0='1') then
count0<=count0+1;
elsif (count1=x"5" and BTN1='1') then
count1<=x"0";
elsif (BTN1='1') then
count1<=count1+1;
elsif (count2=x"9" and BTN2='1') then
count2<=x"0";
elsif (BTN2='1') then
count2<=count2+1;
elsif (count3=x"5" and BTN3='1') then
count3<=x"0";
elsif (BTN3='1') then
count3<=count3+1;
elsif (count4=x"C" and BTN4='1') then
count4<=x"1";
elsif (BTN4='1') then
count4<=count4+1;
elsif(BTN5='1') then
reg<=not(reg);
end if;
else
if (count4=x"C" and count3=x"5" and count2=x"9" and count1=x"5" and count0=x"9") then
reg<=not(reg);
count4<= x"1";
elsif (count3=x"5" and count2=x"9" and count1=x"5" and count0=x"9") then
count4<=count4 + 1;
elsif (count2=x"9" and count1=x"5" and count0=x"9") then
count3<=count3 + 1;
elsif (count1=x"5" and count0=x"9") then
count2<=count2 + 1;
elsif (count0=x"9") then
count1<=count1 + 1;
else
count0<=count0 + 1;
end if;
end if;
end if;
end process;
AM <= reg;
hex0<=count0;
hex1<=count1;
hex2<=count2;
hex3<=count3;
hex4<=
count4 when (count4<x"A") else
"00"&count4(2 downto 1) when count4=x"C" else
"00"&count4(0);
hex5<=
"0001" when (count4=x"A" or count4=x"B" or count4=x"C") else
"0000";
end Behavioral;
    The error is here:
    "00"&count4(2 downto 1) when count4=x"c" else
    "00"&count4(0);
    The bold part is wrong and pointless.
    x"2" when count4=x"C" else
    "000"&count4(0);
    ... probably the error is not this. I see now you described a different behavior
    Wow that is working sir.
    Thank you so much
    If u don't mind plz explain me how to change .pof file extension
    I changed in the file convertor. But it's not work. It shows the error sms.
