ARach7
7 years agoCan you explain why the 3 "arriav" libraries are not listed in library mapping file for VCS, the synopsys_sim.setup that is generated under /simulation/scsim ?
Test-case: $QUARTUS_ROOTDIR/qdesigns/binary_cam. At EDA simulation library compiler, choose CycloneV and arriav and compile the in Verilog. At the synopsys_sim.setup file created for the ex...
Deshi_Intel
7 years agoHI,
I have generated a simple Arria V Transceiver PLL IP core. A sim project folder will be generated as well . Attached is the IP sim folder.
You can find the script "vcsmx_setup.sh" that call out the Arria V library in following path.
- AV_PLL_sim\synopsys\vcsmx
dlim
