11 years agothis is the time to show in LCD. i cannot find the problem. i want to show hour for 01-12. but its also include 00. so after 12hr it become 00hr and then 01 hr. that is the wrong. can u find the error, sir. plz help me. that is very important for me ................. thank sir
------------------------------------------------------------------------------------------------------------------------ library IEEE; use IEEE.STD_LOGIC_1164.ALL; use IEEE.STD_LOGIC_ARITH.ALL; use IEEE.STD_LOGIC_UNSIGNED.ALL; entity counter_up is Port ( clk : in STD_LOGIC; SET : in STD_LOGIC; BTN0 : in STD_LOGIC; BTN1 : in STD_LOGIC; BTN2 : in STD_LOGIC; BTN3 : in STD_LOGIC; BTN4 : in STD_LOGIC; BTN5 : in STD_LOGIC; reset : in STD_LOGIC; AM : out STD_LOGIC; hex0 : out STD_LOGIC_VECTOR (3 downto 0); hex1 : out STD_LOGIC_VECTOR (3 downto 0); hex2 : out STD_LOGIC_VECTOR (3 downto 0); hex3 : out STD_LOGIC_VECTOR (3 downto 0); hex4 : out STD_LOGIC_VECTOR (3 downto 0); hex5 : out STD_LOGIC_VECTOR (3 downto 0)); end counter_up; architecture Behavioral of counter_up is signal count0:std_logic_vector(3 downto 0):=(others=>'0'); signal count1:std_logic_vector(3 downto 0):=(others=>'0'); signal count2:std_logic_vector(3 downto 0):=(others=>'0'); signal count3:std_logic_vector(3 downto 0):=(others=>'0'); signal count4:std_logic_vector(3 downto 0):=x"1"; signal reg:std_logic:='0'; begin process(clk,reset) begin if reset='1' then count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=(others=>'0'); count4<=x"1"; elsif rising_edge(clk) then if SET='1' then if (count0=x"9" and BTN0='1') then count0<=x"0"; elsif (BTN0='1') then count0<=count0+1; elsif (count1=x"5" and BTN1='1') then count1<=x"0"; elsif (BTN1='1') then count1<=count1+1; elsif (count2=x"9" and BTN2='1') then count2<=x"0"; elsif (BTN2='1') then count2<=count2+1; elsif (count3=x"5" and BTN3='1') then count3<=x"0"; elsif (BTN3='1') then count3<=count3+1; elsif (count4=x"C" and BTN4='1') then count4<=x"1"; elsif (BTN4='1') then count4<=count4+1; elsif(BTN5='1') then reg<=not(reg); end if; else if (count4=x"C" and count3=x"5" and count2=x"9" and count1=x"5" and count0=x"9") then reg<=not(reg); count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=(others=>'0'); count4<= x"1"; elsif (count3=x"5" and count2=x"9" and count1=x"5" and count0=x"9") then count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=(others=>'0'); count4<=count4 + 1; elsif (count2=x"9" and count1=x"5" and count0=x"9") then count0<=(others=>'0'); count1<=(others=>'0'); count2<=(others=>'0'); count3<=count3 + 1; elsif (count1=x"5" and count0=x"9") then count0<=(others=>'0'); count1<=(others=>'0'); count2<=count2 + 1; elsif (count0=x"9") then count0<=(others=>'0'); count1<=count1 + 1; else count0<=count0 + 1; end if; end if; end if; end process; AM <= reg; hex0<=count0; hex1<=count1; hex2<=count2; hex3<=count3; hex4<= count4 when (count4<x"A") else "00"&count4(2 downto 1) when count4=x"C" else "00"&count4(0); hex5<= "0001" when (count4=x"A" or count4=x"B" or count4=x"C") else "0000"; end Behavioral;
