12 years ago --- Quote Start --- This what I found in the QII13.0 help: Wouldn't you need an extra register stage before applying the xor to get the output pulse? Regards, Josy --- Quote End --- Yes Josy I will drive xor only after two stages as the signals are assumed synchronised from that node onwards. FvM approach is one stage and is sampling to xor from first synchroniser register. This will fail more frequently than two stage. Since you found the cut path attribute then it means it exists and hopefully still active.
