12 years agoThis what I found in the QII13.0 help:
--- Quote Start --- The following example shows how you can also use altera_attribute for more complex assignments involving more than one instance. In this example, the following VHDL sample uses an altera_attribute to cut all timing paths from q1 to q2: signal q1, q2 : std_logic; attribute altera_attribute : string; -- Equiv to set_instance_assignment -name CUT ON -from q1 -to q2 attribute altera_attribute of q1 : signal is "-name CUT ON -to q2"; You may specify either the -to option or the -from option in a single altera_attribute; integrated synthesis automatically sets the remaining option to the target of the altera_attribute. You may also specify wildcards for either option. For example, if you specify * for the -to option instead of q2, the Quartus II software cuts all timing paths from q1 to every other register in the design. --- Quote End --- Wouldn't you need an extra register stage before applying the xor to get the output pulse? Regards, Josy
