16 years ago
Can using .qxp as source file reduce compilation time?
I would like to know how does using .qxp as source file helps to reduce compilation time in a team-based design environment?
Thanks and cheers!
    I'm pretty sure .qxp as source only supports post-synthesis, i.e. it won't preserve placement and routing. So it certainly will cut down your synthesis time, but wouldn't have any affect on fit time. You'd have to decide if that's worth it. (I think .qxp as source will support placement and routing in the upcoming release. Not positive though.)
    --- Quote Start ---
    --- Quote End ---
    Hi Rysc,
    as far as I know it possible to export the routing ( that also means the Placement). You can choose this option in the "Export Design Partition" tab. After import of the partition in the top project you can choose the fitter preservation level between:
    netlist only
    placement
    placement & routing
    Of course you have to define LogicLock regions for your design partitions in order to make
    sure that no placement conflict occurs.
    Kind regards
    GPK
    You're right. I consider import/export of QXPs, and "QXP as source" to be two different flows, and I was just responding to the latter. For import/export, everything you've said is correct, and probably good that it's clarified.
