16 years ago --- Quote Start --- I'm pretty sure .qxp as source only supports post-synthesis, i.e. it won't preserve placement and routing. So it certainly will cut down your synthesis time, but wouldn't have any affect on fit time. You'd have to decide if that's worth it. (I think .qxp as source will support placement and routing in the upcoming release. Not positive though.) --- Quote End --- Hi Rysc, as far as I know it possible to export the routing ( that also means the Placement). You can choose this option in the "Export Design Partition" tab. After import of the partition in the top project you can choose the fitter preservation level between: netlist only placement placement & routing Of course you have to define LogicLock regions for your design partitions in order to make sure that no placement conflict occurs. Kind regards GPK
