11 years ago --- Quote Start --- Thanks. Yes, fiddling with the Quartus synthesis/fitting options may work in some cases, but the options are very limited. You mentioned "manually placing some cells", do you mean put a register in a failed path to increase a step pipeline as I described? Thanks. --- Quote End --- Unfortunately the person answering this is completely wrong. Timequest set_output_delay and set_input_delay constraints are used to set the external PCB and device input and output delay (including setup and hold time). Timequest does a very good job of this. There is no need to be fiddling with manually placing cells. Search for TimeQuest User Guide by Ryan Scoville.
